Heater only blows hot air when car is moving
2006 FORD FUSION
175,000 MILES • 3.0L • V6 • FWD • AUTOMATIC
VERNICE STRICKLAND
car will blow out cold air when it stops and start back blowing hot when moving. I have already changed the thermostat and top hose with relief valve. fluid level full.
Dec 12, 2016 at 6:36 PM
SATURNTECH9
  • 30,869 POSTS
You could have a restricted heater core that does not allow enough hot coolant into the heater core unless the engine rpms are higher.
Dec 12, 2016 at 8:24 PM
