Car was at operating temp but blowing cold air which I know is common problem on this car. However, temperature gauge went to hot almost immediately. Stop at light and temperature went down while at idle. Went back up when driving. Drove a couple miles to destination and after turning off engine I checked pressure on radiator hose and was able to squeeze hose with no problem. Was inside maybe fifteen minutes when restarted engine temperature read below the normal range. After driving at normal temperature for a few miles I noticed warm air through vents so turned heater on again. Once more went to hot. Now radiator was replaced one year ago along with timing belt, water pump and thermostats all due to same problem. Ran fine through last winter but here I am back to same problem after about 6,000 miles. Any ideas?
Oct 28, 2017 at 3:35 AM
