Heater is not working?
2007 SUZUKI XL7
130,000 MILES • 3.6L • V6 • 4WD • AUTOMATIC
When driving the air blow cold in the packing heater is fine. My mechanic replace the heater core then water pump but still no heater.
Oct 27, 2018 at 5:11 PM
It sounds like you have a temperature blend door actuator that is not working here is a guide to show you the steps and the location for your car is below.
This guide can help as well.
https://www.2carpros.com/articles/car-heater-not-working
Check out the diagrams (Below). Please let us know what you find. We are interested to see what it is.
Oct 28, 2018 at 6:29 PM
LISA DUNCAN
Why is my 2007 Suzuki XL7 heater selector knob not delivering heat where I have selected? And today it started blowing nothing but cold air even though the heater was on. Please help me! It's 14 degrees outside.
Nov 25, 2020 at 8:33 AM (Merged)
It sounds like a vacuum issue. Check under the dash for vacuum leaks. If you are lucky, with the engine running, you may hear a hissing sound.
ANGIET1231
what causes the heater to blow out cold air when the car is idoling
BLUELIGHTNIN6
  • 16,542 POSTS
coolant flow is probably too high, caused by a stuck open thermostat.
BMRFIXIT
  • 19,053 POSTS
Low coolant level ,stuck open thermostat
