heater not working on passenger side
2005 KIA AMANTI
104,556 MILES
ARACA
i have a 2005 kia amanti and the passenger side heater does not work...it blows out cool air.i have a 2005 kia amanti and the passenger side heater does not work...it blows out cool air.i have a 2005 kia amanti and the passenger side heater does not work...it blows out cool air.i have a 2005 kia amanti and the passenger side heater does not work...it blows out cool air.i have a 2005 kia amanti and the passenger side heater does not work...it blows out cool air.i have a 2005 kia amanti and the passenger side heater does not work...it blows out cool air
Nov 4, 2013 at 9:45 AM
If you are getting heat from the driver's side, then you must have a blend air door actuator that is out for the passengers side. Here is a guide that will show you what you are in for when doing the job.
Here is what it will be like for your car I have included both drivers and passengers side actuators. (below)
Cheers
Nov 4, 2013 at 9:49 AM
ARACA
Yep that did the trick, I replaced the passenger's side temperature blend door and the problem is fixed! thanks 2Carpros :)
I love this site
Nov 4, 2013 at 11:22 AM
Good to hear, please use 2CarPros anytime we are here to help.
Nov 15, 2017 at 8:02 PM
CTHOMPSON106
Heater problem
2004 Kia Amanti 6 cyl Front Wheel Drive Automatic 66000 miles
with heat on high and blower on high, no heat entering car. Window fogging
Nov 15, 2017 at 8:02 PM (Merged)
DAVE H
  • 13,384 POSTS
check/replace the thermostat .. check/flush the heater core for blockages !!
2CP-ARCHIVES
  • 4,540 POSTS
The vehicle is in kilometers not miles, I have lots of heat on high, it has a didital heater controlwith auto. when i lower the heat setting 1 degree, the air is cool not hot. It should only be lowered by that 1 degree. any suggestions?
KHLOW2008
  • 41,814 POSTS
Between heat and cool it depends on where the dial is set at. If it is at the borderline, it can mean a lot of difference. The air mixactuator controls that and if it is moving too much, it would close the heater vent resulting in cool air instead of slight heat.
Nov 15, 2017 at 8:03 PM (Merged)
