Okay, it sounds like you have a few different issues. Since the heat is most important at this time, lets start with that.
This guide can help
https://www.2carpros.com/articles/car-heater-not-working
First, I live south of you in PA. Same thing here with temps. Tell me, how long does it take for the engine to warm up? If the thermostat is sticking slightly open, it will take an extended period of time before it warms up.
https://www.2carpros.com/articles/how-an-engine-thermostat-works
Pay attention tomorrow when you drive how long it takes to reach operating temp. Once I know what you find, I can better direct you.
There are two actuators which operate what are called blend air doors. There is one for each side. Their basic function is to allow heat or AC to enter the vehicle. If they are not working properly, they may be limiting the amount of heat entering the vehicle.
____________________________________________________
If you find the engine is taking an extended amount of time to heat up, here is a link that shows how to replace a thermostat.
Here are the directions specific to your vehicle.
Removal and Installation
1. Drain the engine cooling system.
2. Release the clamp and disconnect the upper radiator hose from the thermostat housing cover.
3. Remove the bolts and the thermostat housing cover.
- To install, tighten to 10 Nm (89 lb-in).
4. Remove the thermostat.
5. NOTE: Inspect the thermostat housing cover O-ring seal. Install a new O-ring seal if necessary.
To install, reverse the removal procedure.
____________________________________________________________________
Here are the directions for the blend air door actuators. I will start with the driver's side.
TEMPERATURE BLEND DOOR ACTUATOR - LH
See Picture 3
1. Remove the LH floor console finish panel. See: Console > Removal and Replacement
Picture 4
2. Position the in-vehicle temperature sensor aspirator hose away from the LH temperature blend door actuator.
3. Remove the 3 LH temperature blend door actuator screws.
4. Disconnect the LH temperature blend door actuator electrical connector.
5. Remove the LH temperature blend door actuator.
6. To install, reverse the removal procedure.
TEMPERATURE BLEND DOOR ACTUATOR - RH, EATC
Picture 5
1. Remove the RH floor console finish panel. See: Console > Removal and Replacement
Picture 6
2. Lower the glove compartment.
3. Disconnect the RH temperature blend door actuator electrical connector.
4. Remove the 3 RH temperature blend door actuator screws.
5. Remove the RH temperature blend door actuator.
One last thing. You indicate the air flow is only defrost or lower. The air flow via the vents is controlled by a vacuum motor. Either there is no vacuum to it, something is disconnected, or the vacuum motor has failed.
Here are the directions for replacing it.
VACUUM CONTROL MOTOR - PANEL DOOR
Picture 7
1. Remove the audio control module (ACM).
3. Remove the 3 center panel duct screws and position the center panel duct aside.
Picture 8
4. Remove the 2 plenum chamber screws.
Picture 9
5. Disconnect the panel door vacuum control motor vacuum connector.
6. Remove the 2 panel door vacuum control motor screws.
7. NOTE: The plenum chamber must be slightly repositioned to allow the panel door vacuum control motor to be rotated far enough to clear the retaining arm.
Rotate the panel door vacuum control motor until it clears the retaining arm and remove the panel door vacuum control motor.
8. To install, reverse the removal procedure.
I realize this is a lot. I wanted to answer all questions, so that is why I included these things. Pay attention first to the temperature gauge tomorrow and see how long it takes to reach operating temperature.
Let me know if you have other questions and what you find.
Feb 8, 2019 at 9:13 PM
