Good afternoon,
I attached a wiring diagram for you to view. I highlighted the wire that is power to the blower resistor that feeds the blower motor. Verify power on both sides of the fuse with a test light or voltmeter. This is not a visual test, it is a voltage test.
The blower motor location is attached and the resistor is right next to the motor.
Nov 10, 2019 at 2:58 PM
