I did not have heat at all in my vehicle listed above Platinum. My mechanic said it would be around $3,500.00 to take the dash apart and repair a blend door servo/actuator I pulled the dash apart and all actuators seem to be functioning properly. I then came across the idea of the coolant being air locked. Bled air with front of car elevated and a burp bucket. The heat started blowing warm. I then realized it would blow hot when the engine is revved up to 2,000 RPMs. I flushed water through the heater core with no trash or resistance. I went ahead and flushed the coolant system and installed a new thermostat. I repeated the burping process. I still only have hot heat when at 2,000 RPMs or higher.
Any help would be appreciated!!
Jeremy Gillentine
Jeremy Gillentine
Nov 17, 2022 at 7:48 AM
