The blower motor is under the dash and behind the glove box. There is a good chance the motor is going bad. Here is how to check one. The attached picture correlates with the directions.
______________________________________________
2007 Hyundai Truck Entourage V6-3.8L
Blower Motor
Vehicle Heating and Air Conditioning Blower Motor Testing and Inspection Component Tests and General Diagnostics Blower Motor
BLOWER MOTOR
BLOWER MOTOR
INSPECTION
See pic 1
1. Connect the battery voltage and check the blower motor rotation.
2. If the blower motor voltage is not operated well, substitute with a known-good blower motor and check for proper operation.
3. If the problem is corrected, replace the blower motor.
If you determine the blower motor is bad, here is a link that shows in general how one is replaced. It may help when you replace yours.
https://www.2carpros.com/articles/blower-fan-motor-works-on-high-speed-only
Here are the directions specific to your vehicle for replacing it. The remaining pictures correlate with the directions.
Blower Motor
Vehicle Heating and Air Conditioning Blower Motor Service and Repair Removal and Replacement Blower Motor
BLOWER MOTOR
BLOWER MOTOR
REPLACEMENT
1. Disconnect the negative (-) battery terminal.
See Pic 2
2. Disconnect the connector (A) of the blower motor.
See Pic 3
3. Remove the blower motor (A) after loosening the mounting screws.
4. Installation is the reverse order of removal.
Let me know if this helps or if you have other questions. I do have one other question. When it does decide to turn on, does it work on all speeds or is it limited to high speed only?
Jan 7, 2020 at 8:15 PM
