After my concentric slave cylinder failed, I had it replaced as well as flywheel and transmission parts.
The Gears and clutch pedal now work very well, but strangely when I turn on heating inside the van it does not blow very strongly. This change occurred exactly when I picked my van up with the new slave cylinder. It seems at all fan speeds 1 through 4 the air does not blow strongly but when I put it into reverse and pull back on the clutch pedal the fan blows much stronger (at the strength it should be and indeed was before the transmission repair).
I typically back into my driveway and the full fan strength only comes on when I start to release the clutch pedal in reverse. Also, when I stop the van and put it into neutral, the fan speed goes slower again. This only happens in reverse: when I park forwards, the fan strength does not increase.
Also, when I turn the ignition off, there is an electrical humming for about 1-2 minutes that never happened before the transmission repair. I opened up the bonnet and I can hear the humming. It seems to come from the area of the master cylinder and brake fluid area.
Any ideas?
Any ideas?
Jun 22, 2023 at 9:54 PM
