Welcome to 2CarPros.
It could be a few things. First, if the coolant is full, I want you to try this. Turn the heater on high and start the engine, allowing it to warm up to operating temp. Turn the engine off and feel both heater core hoses. Are both hot? If they are then coolant is flowing through the heater core. If one is hot and not the other, then suspect the core is plugged.
If both are hot, the next thing to suspect is what is call a blend air door actuator. It is what allows the heat to enter the vehicle.
Take a look through this link to see if anything helps:
https://www.2carpros.com/articles/car-heater-not-working
If you decide the problem is the blend air door actuator, here is a link that shows in general how one is replaced:
Here are the directions specific to your vehicle. The attached directions correlate with the directions.
__________________________________________
2001 Dodge Stratus Sedan V6-2.7L
Blend Door Actuator Replacement
Vehicle Heating and Air Conditioning Air Door Actuator / Motor Service and Repair Procedures Blend Door Actuator Replacement
BLEND DOOR ACTUATOR REPLACEMENT
REMOVAL
NOTE: Prior to part replacement, re-calibration the HVAC actuator. Disconnecting negative battery cable for 60 seconds. This will automatically initiate the software calibration procedure.
1. Disconnect negative battery cable.
2. Remove the floor console.
3. Remove rear heat ducts.
4. Remove HVAC housing.
5. Disconnect the electrical connection.
Fig.23 Blend Door Actuator
Pic 1
6. Remove actuator retaining screws and pull actuator straight down. Note actuator shaft position for installation reference.
Fig.24 Blend Actuator Spline
pic 2
INSTALLATION
1. Install blend door actuator on the housing, making sure the shaft spline is positioned properly with the cam.
2. Install tighten the actuator mounting.
3. Connect wire harness connector to the actuator.
4. Install HVAC housing.
5. Install rear heat ducts.
6. Install the floor console.
7. Connect the negative battery cable.
If the heater core is the issue, you can try flushing it. Basically, remove both hoses to it at the firewall and spray water through in both directions. If water doesn't flow, replace the heater core.
Here is a link showing in general how one is replaced:
https://www.2carpros.com/articles/replace-heater-core
Here are the directions for core replacement specific to your vehicle. The attached pics correlate with the directions.
Removal and Replacement
Vehicle Heating and Air Conditioning Heater Core Service and Repair Removal and Replacement
REMOVAL AND REPLACEMENT
REMOVAL
2. Remove HVAC housing from the vehicle. Refer to: "Housing Assembly HVAC : Service and Repair" See: Housing Assembly HVAC > Service and Repair
Fig.18 Recirculation Motor
pic 3
3. Disconnect connector from recirculation motor.
Fig.19 HVAC Harness
pic 4
4. Remove wiring harness connector from the top of the housing.
Fig.20 Evaporator Seal
pic 5
5. Remove seal around evaporator coil inlet/outlet.
6. Remove retaining screw from the top of the housing.
Fig.21 HVAC Housing
pic 6
7. Separate the upper from the housing from the lower.
Fig.22 Heater Core
pic 7
8. Lift heater core out of lower housing.
INSTALLATION
1. Install new heater core into lower housing.
2. Install upper housing onto lower housing and install screws.
3. Install evaporator seal
4. Install HVAC harness on upper housing
5. Connect recirculation motor connector.
6. Install HVAC housing. Refer to: "Housing Assembly HVAC : Service and Repair" See: Housing Assembly HVAC > Service and Repair
Oct 12, 2019 at 9:42 PM
