Heater does not work blows cold
1998 LINCOLN MARK VIII
133,000 MILES
TELLERX
Just bought a 1998 Lincoln and found the heater blows cold when set the temperature to heat also the air conditioning compressor is on and working when my climate control is set on 80-90 degrees, if the blend door is bad would that be the reason that the air conditioning compress is on when i switch to the heat mode
Oct 21, 2013 at 8:54 PM
No, the blend air door and compressor are two different items. It is, however, normal for the AC compressor to run when using the defroster. As far as the no heat problem, have you checked to see if both heater core hoses are getting hot?
Oct 22, 2013 at 5:21 AM
TELLERX
Wow thanx for the quick reply, no haven't checked the heater hoses when operating temperature has been reached will do that tommarrow, however i noticed that the compressor clutch was activated when the the temp control panel was set on heat or air conditioning so now that u confirmed that the blend door has no effect on this event then i can continue checking
Oct 22, 2013 at 9:42 PM
Let me know what you find.
Oct 23, 2013 at 5:32 PM
