For more than six months I have been experiencing coolant loss, recently heater stopped blowing hot air
2007 NISSAN PATHFINDER
200,000 MILES • 4.0L • 6 CYL • 4WD • AUTOMATIC
ROBERTA BAKER
For over six months I have been experiencing coolant loss, recently heater stopped blowing hot air.
I have taken the car to various shops. They are unable to locate the leak, some say it is a blown head gasket, others strongly disagree. The car fails the compression test and overheats. A week ago I had a brand new radiator replaced, since Tire Engineers claimed they finally found the leak in the radiator. Unfortunately the leak is there, everything is the same. Please advice.
Oct 5, 2016 at 8:07 AM
HMAC300
  • 48,601 POSTS
test for a blown head gasket either chemically or by pressure checking coolant system. no heat is usually no or low coolant is the number one cause.
Oct 5, 2016 at 9:39 AM
ROBERTA BAKER
Thanks so much for your reply. Will check.
Oct 5, 2016 at 1:36 PM
SATURNTECH9
  • 30,869 POSTS
Also, air in the cooling system could cause no heat.
Oct 5, 2016 at 9:44 PM
