So I dug around to see if the system was vacuum controlled or electronically. It is electronic. If it was vacuum controlled, I would suggest digging around under the hood looking for vacuum leaks, as that would cause the heat to work the way you mentioned. Since it is not vacuum controlled, I would suggest flushing out and bleeding the system.
If you do no know how, here are some basic instructions. (1) With the engine cold, raise the hood and disconnect the heater core hoses from the engine side. (2) Point one hose where it won't leak on any electrical's or other important stuff. (3) Hook up your water hose to the other heater core hose (you might have to get creative here). (4) Turn the water on, low pressure. (5) Let it run until the water coming out is clear, and then another couple of minutes after that. (6) Unhook the water hose and put the heater core hoses back on. (7) Bleed the cooling system instructions are next.
(1) With the engine cold, raise the hood and take off the radiator cap. (2) Start the car and turn the heat on, full blast. (3) Let the car idle a while, until it starts warming up some. (4) With the car still idling, and the heat on, look down into the radiator and watch the coolant level. As air works through the system, it will come up at the filler area (where the cap goes). You simply fill it whenever the level drops. Repeat the process until the coolant level stops dropping.
Again, good luck and let us know.
Sep 11, 2017 at 6:32 PM
