Hi, I got a new problem trying to fix another. So I was trying to replace the PCV valve and I accidentally (barely) bumped into the smaller coolant hose that goes into the right (passenger side) of the firewall, and the metallic part of the hose looks like it was corroded and snapped. it's an extremely hard to reach area and the other end of the hose is even worse. So since it apparently looks like it has a special quick disconnect on the end that goes into the firewall. what would be the easiest way to go about replacing this? Do I need a special tool or can it disconnect without it? And also since the other end is in a nightmarish spot could I just cut the hose so far down and use a coupling to connect a new hose to the old one? I'm pretty much stuck until then. thanks!
Oct 10, 2019 at 7:23 PM
