Welcome to 2CarPros.
When you say there is no water flowing in the hoses, are you referring to the heater hoses only? Did he bleed the system? Does it overheat if you are driving at highway speed, does it overheat or is it only in stop and go traffic?
I have to be honest, there are many things that can cause an engine to run hot. Things such as a plugged catalytic converter, rich fuel mixture, timing, and many others. I have to assume the people who checked it also inspected the radiator for excessive corrosion, blocked passages in the engine block and so on. Also, this vehicle would have come from the factory with a coolant called Dex-cool. If regular green coolant was mixed with it, that will cause serious cooling system issues.
Also, inspect the water pump for leaks. Here is a link that will help:
https://www.2carpros.com/articles/symptoms-of-a-bad-water-pump
Let me know what you find.
May 16, 2019 at 7:21 PM
