It does but if this were the case that it is a heater core or any other bypass hose, why not just replace it with a rubber replacement line? The only reason it would be metal is if it is in a place that gets hot and it could melt. However, they normally don't route these lines close to heat sources because they want to keep the coolant cool.
It may be necessary for him to show you what needs to be done because you should not have to remove the engine to do any of this. You may have to take a couple things out of the way to get the heater core bypass but it should be too much.
It just seems like something is getting lost between what he is saying and what you are thinking is the issue. That is part of his responsibility to make sure you understand.
Oct 11, 2019 at 8:06 PM
