Heater blows hot & temp gauge in red
1999 FORD FIESTA
80,000 MILES • 1.2L • 4 CYL • 2WD • MANUAL
CHRIS SMITH1971
The heater blows hot air all the time regardless of setting, after about 5 miles the temp gauge goes into red and only cools down when vehicle is stationary and fan cuts in, there are no visible leeks or signs of oil/water mixing coolant level is ok,
Aug 27, 2014 at 7:50 AM
WRENCHTECH
  • 20,761 POSTS
You need to first pressure test the cooling system for leaks. It sounds like it has some air pockets due to a leak.
Aug 27, 2014 at 8:40 AM
