Heater blows cool air
2003 FORD WINDSTAR
1,683,768 MILES • 2WD • AUTOMATIC
PEGGY SUE HAMRICK
  • 4 POSTS
Had a radiator hose leak fixed had to drain water out and put coolant in it.
Dec 3, 2019 at 6:18 AM
Good morning,
Did the heat work prior to this repair?
If it did, you may have air in the system. I would run the van with the cap off at 1200 RPM and have someone watch the coolant level and add as needed. Once the air is out of the system, you will have heat.
https://www.2carpros.com/articles/car-heater-not-working
Dec 3, 2019 at 6:36 AM
PEGGY SUE HAMRICK
  • 4 POSTS
We were wondering how to do that? I know some of them have to be raised on one side.
Dec 3, 2019 at 6:50 AM
No, they do not. Never have and never will be required to do that.
Just run the engine until the thermostat opens and do not let the level go low. That is why you need a second person.
Dec 3, 2019 at 7:02 AM
PEGGY SUE HAMRICK
  • 4 POSTS
Thank you so much, our heater Is working a lot better.
Dec 3, 2019 at 7:16 AM
Good deal.
You are welcome.
Always glad to help.
Dec 3, 2019 at 7:17 AM
PEGGY SUE HAMRICK
  • 4 POSTS
Where is the blower for the back?
Dec 26, 2019 at 7:30 AM
It is behind the trim panels inside the rear hatch.
I provided pictures and a procedure for you.
REMOVAL
1. Remove the trim panels.
2. Disconnect the connectors.
3. Disconnect the rear blower motor.
4. Remove the screws.
5. Remove the vent tube.
6. Remove the rear blower motor.
Remove the screws.
INSTALLATION
1. To install, reverse the removal procedure.
Dec 26, 2019 at 7:44 AM
