The vehicle is the Sport model. When the temperature controls are on heat, the air blend door fluctuates quite often between cold air and hot air. Sometimes it finally stays on heat, other times it stays on cold. The blend door seems to operate normally, so I do not believe it is a faulty actuator, but rather whatever sends the signal to the blend air actuator that is causing it to receive mixed signals. Because the signal to the blend door actuator is somehow compromised, it causes the actuator to fluctuate. Where does the actuator receive its signal from?
Jan 26, 2020 at 10:12 AM
