Blend door actuator location
2007 FIAT PUNTO
70,000 MILES
JAMES WATT
Heater blend door actuator position. Where is the blend door actuator?
Dec 4, 2019 at 2:52 AM
This vehicle isn't offered in the US so my technical information is extremely limited. However, I will try.
If you look under the dash on the heater box, you will most likely find two actuators. One is the blend door actuator and the other the mode door. If there are three, one is for fresh air/re-circulation. What I would do is simply place your hand on one at a time and adjust air flow direction until you feel the one working. Then adjust the one for fresh air until you locate the one working. Once you identified those two, the last one should be the blend air door actuator.
Here is a link that shows in general how one is replaced:
I hope this helps. Please feel free to let me know if you have any general questions.
Dec 4, 2019 at 7:33 PM
