Heater blend door actuator behind glove compartment?
2005 FORD EXCURSION
100,000 MILES • V10 • 4WD
FLUBE66
Original behind glove compartment has stripped gears , have purchased 2 , neither even try’s to work not sure I’m ordering the correct one .
Would you know what the correct part # is please ( bought Dorman parts ? )
Dec 22, 2025 at 1:08 PM
When the blend door actuator is removed try to work the blend door pivot by hand inside the heater plenum, if it is stuck or jammed the actuator will not work. Here is the correct part number you need from Dorman.
Dorman: 604-272
Dorman Products
Ford/Motorcraft OEM references: XC3Z-19E616-BA (also shows as XC2Z-19E616-AA in some OEM
Dec 23, 2025 at 10:48 AM
