Heater barely outputs; access to blend door/procedure?
2001 HYUNDAI ACCENT
151,000 MILES • 1.6L • 4 CYL • 2WD • AUTOMATIC
PHILINSC
  • 7 POSTS
Unit has virtually no heat since a/c season; has historically been very good performer.
Probably heat blend door needs attention, but need to figure out how to access the
upper center forward dash/removal procedure?
Also, I believe this model is cable/pushrod actuated (and sounds that way), but I
understand some models have a motor drive for this door; can anybody clarify?
Nov 29, 2013 at 5:49 PM
HMAC300
  • 48,601 POSTS
it has a cable check to see if it is broken or a clip is broken, try taking glove box out for access and maybe control panel if cable is broken.
Nov 30, 2013 at 6:03 AM
PHILINSC
  • 7 POSTS
Got the glovebox out, but unit is in front of center vents and
is not accessable formthe glovebox area.
Need to know how to get the center or full dash out;
procedure/diagram???
Nov 30, 2013 at 10:01 AM
HMAC300
  • 48,601 POSTS
you may be able to get cables out by removing the two things i'sve sent in pics otherwise you need to remove dash which there are to many pic s to forward on how to do it.
Nov 30, 2013 at 12:29 PM
PHILINSC
  • 7 POSTS
Ok, access did not require removing glovebox or
center dash (unless you would need to replace the cable);
all the heater control cables/levers are just above
the gas pedal, and no covers have to be removed.
The inop conditions showing hot and cold settings:
cable jacket is loose from the heater box anchor.
THE CHEAP FIX;
Set knob at full heat, and pivot lever all the way
rearward, and snap into clip [fix hot.jpg]
RTV/silicone cable in place (allow to cure before
moving knob) [rtv hot.jpg]
Seems to work pretty good now, thanks.
Dec 1, 2013 at 12:09 PM
HMAC300
  • 48,601 POSTS
good luck on your fix.....
Dec 1, 2013 at 12:48 PM
