This will be a simple task as far as the fixing part. Getting it out will be a bit harder.
I suggest a a new heater core for sure!
Maybe the cables if they are not moving well
The rest is going to be replacing the thin foam that seals the doors, you will see what I mean when you get in.
Somewhere over the years that have passed, someone decided to engineer a different blower motor into the equation. The replacement motor has a larger body diameter. The original motor protrudes through the firewall through a hole about the same size. In order to install the new style one, you must make the firewall hole bigger.
While the heater is out, this would be a good time to get a new blower motor and make the modification.
My daily driver (1977) had the crappy heater box in it.
I found an 1982 in the salvage yard, I snagged the newer heater out of it (same heater from 1979-1986). Cool thing is that while I was swapping/ upgrading my 1977 I did some measuring off of CJ body/ firewall. I was able to cut my heater box and firewall so that my heater core could be accessed through the firewall. I also chopped my firewall so that the whole blower motor could be removed the same way.
So now, If I remove my battery tray and two homemade covers. The core and blower will come out in minutes, without removing the whole heater. (I have measurements)
I'm going to send my mod pics now. There's a few more, I'm sure you get the idea and other heater pictures on the next answer block.
The Medic
Mar 16, 2019 at 5:50 PM
