As i line up lever and cable/rod to position on gears on actuator and have the temperature knob on say hot air full, as soon as I connect wire connector to actuator the actuator reverses temperature to opposite hot lever/rod/reverses or turns to cold. If I line up lever/rod to cold air with actuator on that position as soon as I connect wire harness, the actuator turns to opposite temperature.
Does this make any sense?
Oct 23, 2017 at 6:24 PM
