Heater/AC blower not working
1998 BUICK REGAL
120,000 MILES • 3.8L • 6 CYL • 2WD • AUTOMATIC
GCLINE
  • 5 POSTS
The fan switch worked intermittently at first then just on high. I have replaced the resistor and checked all the fuses now it only clicks when put on high. I have read that it can be the ignition switch sometimes. I do not want to just replace parts. What else can I check before doing that? Thanks
Aug 8, 2018 at 5:58 PM
This guide will show you how to check the power and ground of the blower motor to help determine if the problem is the fan motor or something else.
https://www.2carpros.com/articles/blower-fan-motor-works-on-high-speed-only
Here is the blower fan wiring diagrams so you can see how then system works.
Aug 12, 2018 at 12:13 PM
