If I can add this happens when the blend door actuator cable goes bad here is a guide in the diagrams below to help walk you through the steps.
After disconnecting the heater/cooler unit side connections of the air mix damper lever cable and air outlet changeover link cable, remove the heater control assembly.
Fig 2: Identifying Cables On Heater Control Assembly
G01087091
Courtesy of MITSUBISHI MOTOR SALES OF AMERICA.
View Full-Screen
AIR MIX DAMPER LEVER CABLE, AIR OUTLET CHANGEOVER DAMPER LINK CABLE REMOVAL
Insert a flat-tipped screwdriver into the control base clip from inner side, and then remove the cable by lifting the claw part of the clip.
Fig 3: Removing Cables From Heater Control Assembly
G01087092
View Full-Screen
INSTALLATION SERVICE POINT
>>A
Dec 4, 2019 at 3:31 PM
