Unplugging the seat adjuster is likely to cause the heater not to work. To disconnect it would require disconnecting the seat module. I will tell you that I feel you are going in the right direction. However, if both seats failed at the same time, then it's unlikely to be an element. I say that simply because for both to fail at the same time would be odd. Here are the components related to the circuit:
HEATED SEAT COMPONENTS
The heated seat system consists of the following components:
- Driver and passenger heated seat switches
- Driver and passenger seat back heater elements
- Driver and passenger seat cushion heater elements
- Driver and passenger seat back temperature sensors
- Driver seat module
- Driver door module
- Passenger door module
If you find it is the element which is bad, here are the directions for replacement. The attached pics correlate with the directions.
2003 GMC Truck K 1500 Yukon XL 4WD V8-6.0L VIN U
Seat Back Heater Element Replacement - Front
Vehicle Body and Frame Seats Seat Temperature Element Service and Repair Removal and Replacement Seat Back Heater Element Replacement - Front
SEAT BACK HEATER ELEMENT REPLACEMENT - FRONT
REMOVAL PROCEDURE
1. Remove the seat from the vehicle.
2. Remove the seat back trim cover.
pic 1
3. Peel the seat back heater off the foam pad.
4. Disconnect the seat back heater harness.
INSTALLATION PROCEDURE
pic 2
1. Connect the seat back heater harness.
2. Install the seat back heater.
3. Install the seat back trim cover.
4. Install the seat in the vehicle.
__________________________________________________
Seat Cushion Heater Element Replacement - Front
Vehicle Body and Frame Seats Seat Temperature Element Service and Repair Removal and Replacement Seat Cushion Heater Element Replacement - Front
SEAT CUSHION HEATER ELEMENT REPLACEMENT - FRONT
REMOVAL PROCEDURE
1. Remove the seat trim panel.
CAUTION: If the passenger seat cushion foam is damaged when you remove the heater element, replace the passenger pressence system in order to prevent personal injury.
2. Remove the seat cushion trim cover.
pic 3
3. Peel the seat cushion heater off of the pad.
4. Disconnect the seat cushion heater wiring harness.
1. Replace the inflatable restraint passenger presence system if the passenger seat cushion foam is damaged.
pic 4
3. Install the seat cushion heater.
4. Install the seat cushion trim cover.
5. Install the seat trim panel.
6. Re-zero the inflatable restraint passenger presence system for the front passenger seat.
Let me know if I can help.
Dec 14, 2020 at 3:31 PM
