It sounds like the dual seat climate control module has gone out but to be sure let's check the fuses #f16 and #f35. here is a guide to help us get started and the fuse location below along with the wiring diagrams and instructions on how to change out the DCSM seat module:
Dual Climate Controlled Seat Module (DCSM)
Removal and Installation
NOTE: When installing a new Dual Climate Controlled Seat Module (DCSM), it is necessary to carry out Programmable Module Installation (PMI). For additional information, refer to Information Bus. See: Information Bus > Programming and Relearning
NOTE: The air bag warning indicator illuminates when the correct Restraints Control Module (RCM) fuse is removed and the ignition is ON.
NOTE: The Supplemental Restraint System (SRS) must be fully operational and free of faults before releasing the vehicle to the customer.
1. Before removing the DCSM, carry out the appropriate steps in the Programmable Module Installation (PMI) procedure. For additional information, refer to Information Bus. See: Information Bus > Programming and Relearning
2. Remove the front passenger seat. For additional information, refer to Seat - Front See: Seats > Removal and Replacement > Seat - Front.
3. Remove the DCSM.
- Disconnect the 3 electrical connectors.
- Remove the 2 screws.
- Remove the DCSM.
4. To install, reverse the removal procedure.
5. Install the front passenger seat. For additional information, refer to Seat - Front See: Seats > Removal and Replacement > Seat - Front.
6. Install the DCSM software data. Carry out the appropriate steps in the Programmable Module Installation (PMI) procedure. For additional information, refer to Information Bus. See: Information Bus > Programming and Relearning
Front Seats
Without Cooled Seats
Control Module
7E5Z14C724A
168.78
With Cooled Seats
Control Module
9U5Z14C724B
260.20
Rear Seats
Memory Module
5W1Z14C724AA
179.20
Jan 21, 2019 at 12:19 PM
