I have seen both the module go out and the heating element go to open circuit. Can I ask if the light goes on when the system is on? If so, I would use a test light to see if the yel/blu wire has power.
This guide can help:
Here is the wiring diagrams for the seat heaters a little larger so you can read it. Also, I would double check fuse #16 in the under hood fuse panel and fuse # 35 in the smart junctions bow with the system on. This can help eliminate the SJB. Check out the images (below). Please let us know what happens.
Feb 9, 2025 at 12:59 PM
