Heated oxygen sensor
1995 TOYOTA CAMRY
145,400 MILES • 1.3L • V6 • 2WD • AUTOMATIC
RICK MULLER2
  • 5 POSTS
Code came up
Apr 28, 2016 at 6:14 AM
HMAC300
  • 48,601 POSTS
so if you don't tell us we can't give an answer we need to know what the code is
Apr 28, 2016 at 6:36 AM
RICK MULLER2
  • 5 POSTS
Im sorry, po135 bank1 sensor1
Apr 28, 2016 at 11:49 AM
HMAC300
  • 48,601 POSTS
this can be a sensor bad, ecm or a short in system try replacing sensor first as it's the heater element and may have burnt out. that is cheapest fix then reset computer and if light goes back on then you can delve into it further.
Apr 28, 2016 at 12:32 PM
HMAC300
  • 48,601 POSTS
info is right but it is on the rh side of engine before the converter.
Apr 28, 2016 at 12:33 PM
RICK MULLER2
  • 5 POSTS
Thank you very much I'm going to pick
Up a sensor now I'll let you know.
Thank you again
Apr 28, 2016 at 2:24 PM
RICK MULLER2
  • 5 POSTS
My book shows 3 heated oxygen sensors any idea which one I should start with. Obd says PO135 O2 heater circuit bank 1. Sensor 1
Apr 28, 2016 at 2:55 PM
HMAC300
  • 48,601 POSTS
I already did on the second reply
Apr 28, 2016 at 3:47 PM
