Engine running hot?
2003 TOYOTA 4RUNNER
223,000 MILES • 4.7L • V8 • 4WD • AUTOMATIC
JONATHAN.925
My cars engine gets really hot in a short period of time, but it does not overheat. I've changed the oil, spark plugs, thermostat, manifold exhaust gaskets and did a radiator flush. Still no luck. Can a 02 sensor cause this much damage?
Jul 7, 2023 at 10:18 AM
The oxygen sensor cannot cause this kind of problem, do you hear the clutch fan kick in when the engine is hot? If not, I would replace the fan clutch.
Here are two guides to help you with instructions below to help you with your truck:
https://www.2carpros.com/articles/fan-clutch-removal
and
https://www.2carpros.com/articles/fan-clutch-symptoms
Check out the images (below). Let us know what happens and please upload pictures or videos of the problem so we can see what's going on.
Jul 7, 2023 at 2:12 PM
