Heat only on one side
2005 KIA SPORTAGE
134,000 MILES
DNLWEGENER
I only have heat coming out of two vents the other two are cold. I have just replaced the thermostat and check all the gears and all the gears seem to be working fine.
Dec 26, 2017 at 4:15 PM
KHLOW2008
  • 41,814 POSTS
Hi DNLWEGENER,
This should be due to a fault with the venting system. The mode control motor is not functioning correctly and it could be bad or a linkage could have detached itself.
Check the air mode control motor under dash and their linkages.
Depending on which 2 vent, either right or left, that is the side you should be checking.
K H Low
Dec 27, 2017 at 9:02 PM
