Looks like I have a problem with the blend door on this car. It has a blend door that will not move from full heat. Blasts full heat and it is not controllable with the single climate control knob.I removed the actuator and tested it and it works fine.However, when I try to turn the blend door spindle that the actuator attaches to, it will not move. (Jammed?)I got access to the passenger side of the HVAC box (removed glove box) and the other end of the blend door spindle, and could not move it from there either. I looked all over the net and YouTube to see if anyone had the same problem. Could only seem to find dual door system problem solving. Is there a way to repair this without pulling the whole dash?I saw that some people had cut the HVAC case to get access to the blend doors.Is this possible with my car?If it is, could you give me some guidance please.Regards, John Russell (74 year young Rocker now in a rocker ;) in the U.S.A.
Apr 8, 2021 at 1:10 PM
