Heat not blowing
2008 CHEVROLET MALIBU
164,900 MILES • 2.5L • 6 CYL • TURBO • AUTOMATIC
AKTION
My heat blows only when I drive other times it does not and my defrost isn't working either.
Jan 12, 2019 at 12:06 PM
The most common problem for what you described (no heat) is due to low coolant. First, follow this link.
https://www.2carpros.com/articles/car-heater-not-working
Next, as far as no defroster, do you mean the air flow direction won't change? If so, that would be related to the mode door actuator. Take a look at the two pictures I attached. They show the actuator replacement procedure.
Jan 12, 2019 at 3:04 PM
