I would check the coolant level first, and if the coolant is okay, start the engine and allow it to get warm, then grasp the heater hoses to see if they are hot which they should be. Please go over this video:
https://www.youtube.com/watch?v=SNRb6pSwYuU&t=1s
If you check everything and still no heat, I would swap out the air mix door (temperature) blend door actuator. Here is the location so you can check it out. Check out the images (below). Let us know how it goes.
Jan 3, 2025 at 6:16 PM
