Hello. Back in July my heat gauge was malfunctioning, sometimes working, and sometimes the needle was at the bottom, when it did this, the hold light would flash on my dash. I went to my local mechanic and they put a new thermostat. Every thing was good, then the same symptoms came back, heat gauge on the bottom zero, check engine light on and hold light flashing on the dash. I then took it to my mechanic again, and they put in a new sensor. When the car is idling the heat gauge works, heat is coming.out hot, gauge on the center line (1/2 way)then as soon as I'm driving, the gauge goes down to the zero and my heat becomes Luke warm. Now the mechanic put a new coil restorer in, and again when idling the heat is hot and gauge is on the middle line, but as I drive down the road., the gauge goes to zero and my heat is lukewarm again. check engine light back on.
At this point I am very frustrated. My mechanic says it's fine, as soon as I leave the shop, the symptoms are back and I've paid for 3 repairs so far.
What could the problem be? Do I need another thermostat? Or what?
Please help.
Jackie M
Please help.
Jackie M
Jan 22, 2020 at 10:25 AM
