Heat does not blow on the driver side, where is the blend door actuator located?
2015 CADILLAC ESCALADE
179,000 MILES • V8 • 4WD
SUMMERKELLEY
It works on the passenger side. I would like to know where the blend door actuator is located on the vehicle listed above when the driver side will not blow heat.
Dec 7, 2024 at 6:48 AM
It looks like the driver's side temperature blend door actuator is on top of the HVAC plenum. Here is how to change it out and the locations well, and I have included how to calibrate it once the repair is completed. Check out the images (below). Let us know if you need anything else.
Dec 7, 2024 at 12:56 PM
