Heat blower not getting power?
1991 CADILLAC FLEETWOOD BROUGHAM
5,000 MILES
KEVIN WOOD
Defrost, heat panel no electricity.
Nov 14, 2024 at 4:48 AM
I would check the fuses first with the systems on, here is a guide to help you test the fuses with the key on. The wiring diagrams below with show you the fuses to check.
If the fuses are okay, I have seen the ECC (electronic climate control) go out in these cars which you can get a used onefrom eBay. Here is the HVAC system wiring diagrams so you can see how the system works and how to replace the ECC as well.
Nov 14, 2024 at 11:14 AM
