Heat and air
2007 PONTIAC G5
150,000 MILES • 4 CYL • 2WD • AUTOMATIC
ASHLEY ADAMSON
There's no blowing of either on any settings Could it be the blend door?
Mar 18, 2019 at 6:40 AM
D6SPAN
  • 58 POSTS
Hi Ashley,
If there is no blowing at all, from any vent, then the problem would likely lie with your blower motor resistor or the blower motor fan itself. Do you hear the fan kick on? Are you getting air flow from any other vents? If you are, then it could be the blend door keeping you from getting air circulation.
Here are a couple of articles for you to familiarize yourself with those components.
How to Replace A Blower Motor Fan:
https://www.2carpros.com/articles/blower-fan-motor-works-on-high-speed-only
And How To Replace a Blend Door Actuator:
Mar 18, 2019 at 12:22 PM
