heat air blower fan
2005 MERCEDES BENZ C240
305,000 MILES • 2.6L • 6 CYL • 2WD • AUTOMATIC
BILL KIEKEL
Watched your video on remove and replace the blower fan. mine was not working at all even defrost. took out blower unit. on floor of car turned on defrost and fan worked. seemed to also work on A/C. thought maybe the wiring plug had not been in fully. put unit back in place and it does not work on defrost or A/C. do not know what to try?
Mar 12, 2018 at 10:00 AM
Hey Bill,
It does sounds like a connection problem does the connector fit well? Also, test the system grounds. Here is a guide and a blower motor wiring diagrams to help us see how the system works:
https://www.2carpros.com/articles/blower-fan-motor-works-on-high-speed-only
and
Check out the diagrams (below).
Mar 13, 2018 at 12:05 PM
BILL KIEKEL
I removed the blower again and it worked on passenger side floor on all speeds. Put it back in and everything is working properly again. Must have been a connector contact problem. Thank you
Mar 13, 2018 at 2:20 PM
Nice work, we are here to help, please use 2CarPros anytime.
Mar 13, 2018 at 2:26 PM
