Heater blowing cold air
1996 CHEVROLET 1500
220,000 MILES
STRELESKMIKE
I have replaced thermostat and heater core it is topped off on coolant both hoses are getting hot, but I still only get cold air to blow out. any ideas?
Mar 17, 2018 at 10:30 AM
JGONZO2398
  • 372 POSTS
I have done those same procedures on my 2002 Ford Taurus, plus I also replaced the blend door actuator, which I would suggest replacing. In my case, that did not fix my no heat problem, so it all adds up to the actual blend door/plenum chamber that moves in order to release hot or cold air. But my best bet for now is that it is your blend door actuator.
Just my two cents though. Hope it helps!
Mar 17, 2018 at 10:35 AM
JGONZO2398
  • 372 POSTS
Here is the actuator for your truck on Autozone.
Mar 17, 2018 at 10:39 AM
JGONZO2398
  • 372 POSTS
I do not know what exact engine you have or if it is P/U (Pickup) or SUB (Suburban), but I am sure this part would fit both regardless.
Mar 17, 2018 at 10:41 AM
STRELESKMIKE
Thanks for the ideas. I will try getting the actuator next Friday and it a 4.3 l v6 two wheel drive pickup.
Mar 17, 2018 at 10:58 AM
JGONZO2398
  • 372 POSTS
No problem, I hope it helps, and let me know! I checked the part again with the information you gave me and it is a fit. I guess it does not matter what engine it is, V6, V8, whatever. But I have posted another screenshot of the blend door actuator, same brand (Dorman), and much cheaper. So I would suggest just buying that one.
Mar 17, 2018 at 11:05 AM
JGONZO2398
  • 372 POSTS
Here is a link to the actual replacement procedure:
Mar 17, 2018 at 11:06 AM
STRELESKMIKE
Thank you for all of this it will make the process much easier and I will let you know next week if it works.
Mar 17, 2018 at 11:07 AM
