First of all the owners manual says 1998 but the door jamb sticker says 9 of 1999. Anyways, the temperature gauge on the dash only reaches about a hundred and twenty degrees which is actually accurate to the infrared reading I took off the engine after running it 20 minutes. I tested the thermostat in boiling water and it seemed to be closed and then open up when the water got hot whether it was exactly a hundred 85 degrees when it opened I don't know but it did appear to open. I cannot see coolant circulating in the radiator when the cap is off and the engine is warm. Several questions could I still have a faulty thermostat? Could I have a faulty water pump. Third could I have a clogged radiator? If you have other suggestions I'm all ears. Thank you for your assistance as always.
Feb 18, 2021 at 9:13 PM
