Hearter blows cold air
1996 BUICK SKYLARK
113,000 MILES • 3.1L • 6 CYL • 2WD • AUTOMATIC
SMITH TAMI
The heater blows cold air . The blower works air conditioner works fine . What's wrong with the heater?
Mar 10, 2019 at 4:36 PM
SCGRANTURISMO
  • 4,897 POSTS
This could be a problem with your heater core. The heater core is like a little radiator that is usually located within your vehicle's dashboard. It is enclosed in a Heating and Ventilation Control (HVAC) unit. Coolant is constantly passed through the heater core as it is an integral part of the engine cooling system. When the driver turns up the temperature control a door on the housing of the heater core opens letting the hot air be introduced into the HVAC ducting system. The amount of hot air let out depends on how hot the driver turns the knob to.
What usually happens is that the heater core starts to leak or gets plugged up rendering the heater inoperative. I have included a couple of links for you down below.
https://www.2carpros.com/articles/how-a-car-heater-works
https://www.2carpros.com/articles/car-heater-not-working
https://www.2carpros.com/articles/replace-heater-core
Please go through these guides and get back to us with what you find out.
Thanks,
Alex
2CarPros
Mar 13, 2019 at 9:10 PM
