The headlights turn on and off by themselves. so far have replaced headlight resistor.
Oct 13, 2016 at 5:25 PM
JOHN BLY
MEMBER
Low beams work, but will not stay on high by using signal switch.
Oct 13, 2016 at 6:04 PM
HMAC300
CERTIFIED EXPERT
I assume fuses under hood have been checked. multi function switch is the more than likely the culprit you can test with headlight on. It might be tan wire at switch burned out.
