With all switches turned off, key out of ignition, doors closed, the lights are still on, but dim. I have to pull the fuse or disconnect battery to get them to turn off. This has happened twice now. If I start the truck and turn the headlights on, they are at regular brightness. But when everything is off, the lights remain on but dim. I took it to my mechanic but he could not reproduce the problem (of course) and said that they may have to replace the under-dash fuse box at $500.00. There's got to be an easier, less expensive solution!
I know this has been an issue with other Ridgeline owners because I see the same question posted on different blogs, but no viable responses. One said it may be a sticky Headlight Relay Switch, but I cannot find any reference to a headlight relay switch or where it is located.
Any ideas, suggestions?
May 27, 2019 at 9:59 AM
