try a different key then have a local pro scan it to see what is wrong with security system if ignition was changed it will have to be reprogrammed or if key was as well
Jan 20, 2016 at 6:59 AM
HMAC300
CERTIFIED EXPERT
sorry previous one was wrong answer . check fuses and relay under hood in fuse box. if those are ok have it scanned for codes as it may be the body module.
