Headlights flashes sometimes when i drive
2011 KIA
55,302,036 MILES • 3.5L • 6 CYL • FWD • AUTOMATIC
BAKHTIAR DUSKY
  • 96 POSTS
hey guys, recently i got this issue with headlights sometimes it flashes when i drive it is rare, but i would really know if it is a real issue or not. thanks
Nov 30, 2016 at 10:21 PM
CARADIODOC
  • 34,306 POSTS
There are two things to look for, (three if computer controls are part of the circuit). In the past, head light switches have had internal auto-resetting circuit breakers in case a wire became shorted. Often the contacts for that circuit breaker became pitted or arced, and that caused them to overheat to the point the breaker would trip, then quickly reset. Those built-in circuit breakers caused much more trouble than they prevented. The clue typically was the flickering occurred more often when using the high beams because they draw more current. On most older cars, arcing of the circuit breaker also caused the tail lights and dash back-lights to flicker. If you're fortunate enough to see that, the cause of the problem has to be before the dimmer switch.
Another common cause is burned terminals at the head light switch or at the dimmer switch. You need to look at the connectors, and if you find one or two blackened terminals, that switch must be replaced, and the black terminals must be cut out of the connector, then they are replaced with individual terminals that can be plugged in separately. When terminals overheat, you will also find about four inches of their wire is hardened. That must be cut off too because solder wont stick to that. Splice in new wire, crimp the new terminals on, but solder them too. Seal the splices with heat-shrink tubing. Never use electrical tape in a car because it will unravel into a gooey mess on a hot day.
If you cannot find a bad switch or connector terminal, we will need to connect something that lets you see where the problem is occurring. Typically we would connect a test light on the wire that goes from the head light switch to the dimmer switch. If the test light flickers when the head lights flicker, the cause of the problem is before that point. If the test light does not flicker, move it further down the line, then watch what happens the next time the problem occurs.
Some newer cars use relays to turn the head lights on. Those will be in the under-hood fuse box. If you have those, swap the head light relay(s) with one of the other ones like it. If the relay was the cause, the lights will no longer flicker.
Nov 30, 2016 at 10:49 PM
BAKHTIAR DUSKY
  • 96 POSTS
Sorry for the delay but i have checked everything like Fuses and Relays and also the connection between the bulbs and everything it seems to be fine .to be more specific it only happens sometimes when i drive on unpaved roads .on paved roads it barely happens.
May 2, 2017 at 3:44 AM
CARADIODOC
  • 34,306 POSTS
Are the lights flashing on when they are supposed to be off, or flashing off when they're supposed to be on?
May 2, 2017 at 2:31 PM
BAKHTIAR DUSKY
  • 96 POSTS
When they are on it happens
May 17, 2017 at 1:09 AM
BAKHTIAR DUSKY
  • 96 POSTS
it just flashes on and off its like blink .it only happens on unpaved roads .i went to the mechanic and he checked every relay and fuses and even used ODB but he said i could not find anything .he said check of the headlights indicator flashes off and on as well or its only the headlights
May 17, 2017 at 5:11 AM
CARADIODOC
  • 34,306 POSTS
You didn't list a model so I can only offer some general suggestions. I think I would be looking at the multi-function switch, (turn signal switch), if that is where your dimmer switch is built into. Given that rough roads is a contributing factor, my suspicion is there is an intermittent connection, either at a connector, or inside the dimmer switch assembly.
The way I would approach this on my own vehicle, where time is not an issue, would be once I knew if it was the low beams, high beams, or both with the problem, I'd connect a voltmeter to a wire in that circuit, then watch what happens to the voltage on that wire when the flashing occurred. If the voltage remains steady, the defect is further down the line, so I'd move the meter's probe to the next test point. If the voltage changed while the problem occurred, the defect is before that point, so I'd move the meter to the previous test point in the circuit. That can be a time-consuming way to locate the cause, but it avoids wasting money on parts that aren't needed.
May 18, 2017 at 1:16 AM
BAKHTIAR DUSKY
  • 96 POSTS
well the Model is 2011 and the services checked multi-function switch they said its not issue.
and for 2 days i have been driving in rough roads and that problem didnot happen .so its really rare but its annoying .they told me check the indicator headlights on dashboard if its also gonna off and on when the flashes happen
May 20, 2017 at 3:45 AM
CARADIODOC
  • 34,306 POSTS
"2011" is the year your vehicle was built. Kia made 8 different models that I have information for but they use very different electrical systems and wiring diagrams. You need to tell me the model if I need to look at the wiring diagram.
May 20, 2017 at 6:02 PM
BAKHTIAR DUSKY
  • 96 POSTS
Kia Cadenza 2011
May 20, 2017 at 10:27 PM
CARADIODOC
  • 34,306 POSTS
Rats. I don't have information for that one. Chances are there are little or no computer controls yet to complicate the head light system unnecessarily. Using a typical wiring diagram I have etched in my mind, the way I would approach this is to find the wire that goes from the head light switch to the dimmer switch, (typically in the turn signal / multi-function switch), and connect a voltmeter to that so I could watch what happens when the lights start flashing. That would tell me which way to go from that point.
I looked at some other 2011 Kia models, and they do indeed have a very complicated computer involved with the head lights. If that applies to your model, your mechanic will need a scanner that can access those computers so he can see what commands it is seeing and responding to. That usually requires driving the vehicle with the scanner connected until the problem acts up.
Since rough roads affect this, you might want to wiggle the wiring harnesses and connectors to see if you can make the lights flash. That would identify the place to look for a bad connection or corroded connector terminal. Sorry that I don't have a better answer for this.
May 20, 2017 at 10:44 PM
BAKHTIAR DUSKY
  • 96 POSTS
thanks dude i really appreciate your help,well its really rare but i am driving in rough roads and it has been 3 days and still no issue yet i am trying to figure out .i will try to have an OBD portable one connect to Car and when that happens it may record and see the results .
May 21, 2017 at 3:10 AM
CARADIODOC
  • 34,306 POSTS
Keep me posted on your progress. I'm sorry that I don't have a wiring diagram I can look at, but I'll offer any suggestions that might be of value.
May 23, 2017 at 12:08 AM
