headlights
1991 SATURN SPORT COUPE
211,000 MILES • 1.9L • 4 CYL • 2WD • MANUAL
WLHANSEN1
  • 12 POSTS
pop up headlight doors do not come up and i have no volts to the acuator motors. Are there control moduals for them and where are they located if so?
Jan 30, 2016 at 7:39 AM
JOHNNYT73
  • 924 POSTS
check fuses first
Jan 30, 2016 at 8:02 AM
WLHANSEN1
  • 12 POSTS
Did not find any fuses blown
Jan 30, 2016 at 8:27 AM
WLHANSEN1
  • 12 POSTS
Did not find a fuse for pop up door! wounder if it has one?
Jan 30, 2016 at 9:07 AM
SATURNTECH9
  • 30,869 POSTS
Just to add to this one there is a head light module under the drivers side wheel well liner.
Jan 30, 2016 at 10:19 AM
SATURNTECH9
  • 30,869 POSTS
Also in the underhood fuse box fuse numbers 5 and 20 are the left and right headlights motor fuses.
Jan 30, 2016 at 10:24 AM
WLHANSEN1
  • 12 POSTS
Thank you Saturntech9 I will do some testing with my test light
Jan 30, 2016 at 12:17 PM
WLHANSEN1
  • 12 POSTS
Both motor fuses were blown after replacing them both doors opened but they will not close. Thinking the control modual may have a problem, but I dont have time today to find and test it.
Jan 30, 2016 at 1:45 PM
WLHANSEN1
  • 12 POSTS
Now I have current to the right motor but not the left and niether will go up or down. The fuses are both good. Any Ideas out there?
Feb 1, 2016 at 4:10 PM
SATURNTECH9
  • 30,869 POSTS
Have you checked the headlight harnesses for damage?they get damaged from you going up and down.Atleast for the headlight bulb anyways.Have you located the headlight light module yet?I have seen a few of those go bad over the years.
Feb 3, 2016 at 12:26 PM
WLHANSEN1
  • 12 POSTS
Have not located the door motors module yet. Took the air cleaner box out hoping to see it. Iguess I will have to take the tire off and well shield to see it.
Feb 3, 2016 at 3:24 PM
SATURNTECH9
  • 30,869 POSTS
I will try to find you the trouble tree for it .
Feb 4, 2016 at 6:29 AM
WLHANSEN1
  • 12 POSTS
Thank you.
Feb 4, 2016 at 2:18 PM
SATURNTECH9
  • 30,869 POSTS
Have you checked to make sure you have a ground to the headlight motors ?
Feb 5, 2016 at 7:49 PM
WLHANSEN1
  • 12 POSTS
I am taking wheel well shield off this morning to better see things. hopeing for abroken wire or bad ground.
Feb 6, 2016 at 6:26 AM
WLHANSEN1
  • 12 POSTS
module is burnt up
Feb 6, 2016 at 1:07 PM
WLHANSEN1
  • 12 POSTS
Two of the six wires green and black dont have juice on the input side of module also but i dont have a diagram. I dont know why it burnt up.Any ideas?
Feb 6, 2016 at 1:14 PM
SATURNTECH9
  • 30,869 POSTS
Age they go bad eventually like anything explains why both fuses were blown let me find you a wire diagram.Also finding a module for that might be challenging.Let me do some looking around.
Feb 6, 2016 at 2:01 PM
WLHANSEN1
  • 12 POSTS
Thanks for the help SaturnTech9
Feb 7, 2016 at 7:37 AM
SATURNTECH9
  • 30,869 POSTS
Your welcome glad I could help.
Apr 23, 2016 at 8:48 AM
