Headlights not working
1998 CADILLAC DEVILLE
64,000 MILES • V8 • 2WD • AUTOMATIC
RONALD DRENNAN
  • 5 POSTS
All the lights on my car work, except my Headlights. I can only operate my car in the daytime. They were working fine last week. I just bought the car in September from a used car lot. I pulled all the mini fuses from the fuse block under the hood. they were fine, nothing broken or burned out. When I pull out the Headlight knob to the first position, the running lights come on. When I pull out the knob again, the headlights do not come on. Also, I have the Twilight Lever turned off.
Oct 15, 2021 at 8:07 AM
SQM
  • 6,383 POSTS
There is a relay for the headlights located in the under-hood fuse box.
Check that relay, maybe you can swap it with a similar one next to it and see if the light comes on.
The relay can also be tested.
I have attached the diagrams below.
Thank you.
Oct 15, 2021 at 8:56 AM
RONALD DRENNAN
  • 5 POSTS
Which one is the Headlight Relay Switch? A video would be nice. Finding it, testing it, how to replace it?
Oct 15, 2021 at 9:17 AM
SQM
  • 6,383 POSTS
I have circled the relay on the chart below. It shows the orientation of it.
Also attached a picture of what the relay looks like.
This is a guide that shows how to test any relay step by step:
https://youtu.be/Hlna_kUt7As
The relay will simply pull out just like a fuse.
Oct 15, 2021 at 10:47 AM
