Headlight Switch question, what is the function of the four settings?
2005 FORD EXPEDITION
200,000 MILES • 5.4L • V8 • 4WD • AUTOMATIC
OREO101
  • 103 POSTS
Hi, I lost my owner's manual to check this.
May be a stupid question.
What is the function of the 4 settings?
I think I have a parasitic drain on battery.
I have a new battery and I fully charge but it will be drained in 2 days.
I understand that I can pull the negative battery cable then put a multimeter set at DC milliamps and if I get from 20 to 50 milliamps that's okay but anything above 50 there's a definite high drain?
Thanks for all your help!
Feb 8, 2023 at 4:28 PM
Based on the switch you have, from left to right the settings are:
1) Automatic
2) Off
3) Parking lamps
4) Headlamps
5) For Lamps/which requires you to press the toggle switch
6) Interior/cluster dimmer switch.
Is that what you needed?
Let me know. Also, take a look through this link that describes how to locate a parasitic draw.
https://www.2carpros.com/articles/car-battery-dead-overnight
Let me know if this helps or if there is anything I can do to help.
Feb 8, 2023 at 7:44 PM
OREO101
  • 103 POSTS
Yes, that helps! I thought the first position from the left was for fog lights?
Thanks for this!
Feb 15, 2023 at 11:45 PM
You are very welcome. The fog lights turn on by pressing the headlamp switch. Nothing is ever simple anymore. LOL They had to throw a push button in there, too.
If you need help or have other questions, let me know.
Feb 16, 2023 at 5:01 PM
